Electric Sump Pump not draining wash basin
4
- - New York City
hi, i'm a new boat owner and just purchased a new Beneteau 323. The pump in the head had been working fine until this morning, and after showering this morning the water wouldn't drain. the pump started to make a whinier noise - not sure if this meant the hose would possibly be blocked or if the pump is damaged (already?).. any ideas or thoughts? the valve is open, and there's nothing that should have been able to get in to the drain that could have clogged it thanks!
Ctskip
Sep 21, 2005
732
other 12 wet water
sounds like a blocked line
Time to trace the lines and disconnect the line to the pump and see if any water exits.If not, its either empty or clogged.Just trace the lines and keep disconnecting until you find the clog. It's there . If not clogged, the pump is malfunctioning. Good luck and keep us updated.I'd call the dealer and ask them. After all the boat is new,right? Keep it up, Ctskip
C
Ceebee
Drain
I believe that the shower drain is connected to the icebox drain. Try to see if the valve under the icebox is open, and if so, close it and the shower drain will work.
Tim
You would be surprised...............
.....how much hair and junk goes down the drain when you shower. "there's nothing that should have been able to get in to the drain that could have clogged it"
Jul 14, 2006
4
- - New York City
re: You would be surprised...............
haven't checked yet, but the reason why i don't think the drain is clogged is because i've used the shower two times now, and my hair is about 1 inch long (and no hair has ever accumulated in my shower at home)
Tim
Do you...............
...........wax yer chest and yer arse? Just kidding....it's Friday. I'd still check everything. It could even be debris from the build. Good luck. Tim
MG
type of pump?
I don't know what type of pump is on your system, but I would bet it's a good chance the impellor is gone, should be an easy,although messy fix. Impellors are cheap. MG
NYSail
Jan 6, 2006
3,187
Beneteau 423 Mt. Sinai, NY
Strainer
My pump for my shower can with and recommended the instillation of a strainer so hair and other debris from the body do not get caught in the impellor. Find the pump and the strainer should be there
