Electric Mast Stepping
Apr 25, 2019
11
Catalina C18 Fort Walton Beach
I love the Catalina 18 but getting a little old to manually Step the Mast. The Norther Freight 2500 winch did the trick. Mounted the winch inside the cabin and ran the cable to pulley attached to the front cleat. Really works well when stepping the mast for bridges and underway.
I attached the shelf using 2 swim platform braces attached to the cabin supports.
3,639
Catalina 30 MKIII Chicago
Nice! I did almost the same thing with an ATV winch but attached it to my trailer. My cable is currently jammed between the spool and the gearbox housing. I assume your cleat block keeps it from getting jammed?
Should you accidentally lose the wireless remote a new remote and receiver unit can be ordered from ebay. Wire colors should match up (hence the reason for no instructions)
Apr 25, 2019
11
I used bought the mounting plate to attach the roller guide infront of the winch and the pulley keeps it straight. I had a binding problem also until I went to the Synthetic winch line. What an improvement and wont rip your sails. lol Thanks for the remote advice, lost my remote and bought a whole unit again.
Sep 24, 2018
3,639
Raising the mast barely stresses my little ATV winch so I know this thing has loads of power that can cause damage. I never though about raising sails with it. Have you tried pulling up an anchor?
Apr 25, 2019
11
I have used this winch to raise and lower the mast. I don't go tight with it, I grab the roller furler to finish the last 3 inches. I am in salt water so did not use the cable when anchoring but I have use the Synthetic winch rope cable to lower and raise the anchor. Very helpful when anchoring is tight spaces.
I looked for a less powerful winch but for $49 this works well. The smaller anchor winches I looked at were expensive
Cable is non forgiving so I changed to the Synthetic rope and cut down on weight.
Likes: LloydB
Sep 24, 2018
3,639
Wow that's cheap! Where'd you find one for $49? I just checked Northern Tool and Harbor Freight.
I noticed that mine doesnt have any kind of brake so a heavy load could slip back. The gears do provide quite a bit of resistance but it's something that should be noted
Apr 25, 2019
11
Harbor Freight runs the $49.00 special. The smallest 2500 does have a gear break and handle for free spooling. I can stop in mid lift to adjust the stays without it budging. That's in high winds and waves. The Synthetic Rope was only $26.00. If you use the original cable take about 20' off the spool and you don't get the jamming. The 50' Synthetic rope fits better on the spool than the cable. By the time I cut the cable and made the new hook loop it would have cost more than the Synthetic Rope. If your worried about damage use a line snubber to give you a little more space if you do get it too tight.
Sep 24, 2018
3,639
That's good to hear about the cable length and synthetic line working. There is a single ferrule on the winch end of the cable in the event that you need to shorten it for a more reasonable price.
The ATV winch holds the cable in place with the minimal loads I put on it. I did use it once to help adjust the boat's position on the trailer at the ramp. It was struggling a lot. The battery was near the end of it's life so I'm sure that also had an impact on its performance. That boat is a Starwind 19 that weighs about 1600 lbs with gear.
