It is too good to be true. That would be the same as a perpetual motion machine. You can use an electric motor as a generator, though. As for the tesla car and battery pack and similar technology in a boat, anything's possible ($). The tesla basically runs on laptop batteries. Lots and lots of them.Why can't they come up with a electric motor that charges itself? Draw power to operate on one end, while charging on the other. If it sounds to good to be true, you can rest assured a oil company owns it.
Keep it up,
Ctskip
From Wikipedia
Battery system
Tesla Motors refers to the Roadster's battery pack as the Energy Storage System or ESS. The ESS contains 6,831 lithium ion cells arranged into 11 "sheets" connected in series; each sheet contains 9 "bricks" connected in series; each "brick" contains 69 cells connected in parallel (11S 9S 69P). The cells are 18 mm (0.71 in) in diameter and 65 mm (2.6 in) long (18650 form-factor); this type of lithium-ion cell is also found in most laptop computer batteries.[9][44][45]
A full recharge of the battery system requires 3½ hours using the High Power Connector; in practice, recharge cycles usually start from a partially charged state and require less time. A fully charged ESS stores approximately 53 kWh of electrical energy at a nominal 375 volts and weighs 992 lb (450 kg). The Tesla Motors Club bulletin board has estimated the 2008 replacement cost at approximately $20,000; this cost is likely to decline in the future. The ESS is expected to retain 70% capacity after 5 years and 50,000 miles (80,000 km) of driving (10,000 miles (16,000 km) driven each year). Tesla Motors provides a 3 year/36,000 mile warranty on the Roadster with an optional 4 year/50,000 mile extended warranty available at an "additional cost" (2008 Roadster buyers receive the 4/50 extension at no cost while later purchasers need to pay).[14][46]
The pack is designed to prevent catastrophic cell failures from propagating to adjacent cells, even when the cooling system is off. Coolant is pumped continuously through the ESS both when the car is running and when the car is turned off if the pack retains more than a 90% charge. The coolant pump draws 146 watts.[47][48] [49] Tesla Motors announced plans to sell the battery system to TH!NK and possibly others through its Tesla Energy Group division. That plan was put on hold by interim CEO Michael Marks in September, 2007.[50][51][52]"
