Edson Drive Wheel Replacement
nfg2u
Feb 13, 2016
92
Hunter Legend 35.5 Fort Pierce
I pulled the Edson Drive Wheel off my 35.5 Legend today. There was corrosion around the block on aft portion of the wheel where the cables attach to the wheel. There was more corrosion in the bolts holding the drive wheel together. In the process of removing the wheel there were cracks in the wheel casing itself. I am in the process of talking to Edson now to get a new wheel.
Here are pictures of the rudder post where it enters the cockpit. There seems to be a missing cover that goes on top of the yellow gasket. I do not know what it looks like but you can make out the outline in the sealant on the deck. I have an email into Hunter Owners to see if they know anything.
Also the rudder shaft/post is hollow and seems to be holding water. Is that normal?
Thanks
Steve
I will be replacing the chain and cables as well as the throttle and shifting cables.
4,265
Pearson 37 Lusby MD
Can't answer your specific questions, but that is a steering quadrant. I know mine was in pretty rough shape last summer when I had my cockpit sole replaced. The boatyard cleaned it up pretty well before re-installing.
nfg2u
Feb 13, 2016
92
So it seems after sucking the water out of the rudder shaft, the shaft has been filled at some time with something. :) anyway, I will try to cap the rudder post when I reassemble .
6,243
S2 9.2a Fairhope Al
from the looks of that pic of the quadrant i may clean up very well ....find a mechanic shop that has a glass bead blaster and have it cleaned ...that is a lot cheaper than purchasing a new one
Dave Groshong
SBO Staff
Staff member
Jan 25, 2007
1,864
Catalina 22 Seattle
Here's a sketch from Hunter, it shows a 2 inch plastic spacer in that area; a co-worker who worked at Hunter for 23 years doesn't recognize that yellow piece.
nfg2u
Feb 13, 2016
92
Thanks, the drawing matches what I am looking at.
Jun 9, 2008
1,771
- -- -Bayfield
A quadrant for steering is shaped like 1/4 of a round pie. A quadrant for steering is like the whole pizza pie that is round. I am pretty sure you have a quadrant and not a radial.
Feb 14, 2014
7,446
Hunter 430 Waveland, MS
It looks good to me!
That is standard look as the galvanization thins. All of your pictures of corrosion are not severe enough to do anything IMHO. Blasting it will also remove the zinc. Rust is a good thing if it is not disturbed. Rust is NOT a virus. If it really bothers you, put on a rust neutralizer, then use a spay on galvanizer or Rustoleum.
Make sure the PO has not changed Edson original design material selection. These rudder materials are not normally effected by galvanic corrosion.
At least the galvanizes cable in pict#2 looks good too. The only minor corrosion notable is in the valleys of the wheel. It appears like rain water has been captured there in the past. Standing water on galvanized parts is not good.
Here is a recent picture of mine.
It passed my inspection, as did the 316 SS rudder post that is passive or galvanically isolated. Good Hunter design.
If you have a close up of the helm wheel crack, it might be informative as to the cause.
Jim....
Sep 23, 2009
1,475
Given the expense and need to custom bore the drive wheel have you considered welding those cracks if they are bad. Also check the idler wheels bracket as the dissimilar metals often rust thru around the bolts. Now would be the best time to repair it if necessary.
Likes: woodster
nfg2u
Feb 13, 2016
92
I have not, I will take it to the machine shop today and see if it's repairable. Thanks for the advice.
nfg2u
Feb 13, 2016
92
The machine shop would not weld the old drive wheel. So some asked about why this one failed. The short answer. I believe that I cracked in taking it apart. The deck cover over the drive wheel had been rotten for some time, I believe that there was excessive corrosion due to the constant moisture in the area just above the wheel. Here are some pics of the wheel and the cover. Also the newly installed wheel.
nfg2u
Feb 13, 2016
92
The bolts were so corroded that it took a 6 foot pry bar to get them to break loose. Lots of anti-seize was used installing the new wheel.
4
Hunter Vision-36 Port Credit Yacht Club
Not sure if its correct to revive this thread or start anew:
Removed my drive wheel (36 Hunter Vision) this winter and in process of replacing it. Also cracked - almost exactly same condition as above. Interesting on measuring the drive wheel it was significantly (I consider 0.15" to be so anyway) smaller diameter bore than the shaft! I concluded forcing this misfit and tightening this had caused the cracking around the retaining bolt hole; the replacement is bored to several 00's larger and fits snugly.
Now I'm curious - what holds the shaft in place? As it dropped an inch or so when the retaining bolt was removed (before I was able to support the rudder underneath) it seems to me it's entirely held in place only by this bolt? If this is the case it could explain why the drive wheel stop has been digging into the fibreglass - the wheel movement seems to have worn away the UMHW spacer and it has been gradually working lower?
Wondering if I should add 2 (stainless?) washers between the spacer and wheel to eliminate further wear? Or should I simply try to replace the spacer?
