I pulled the Edson Drive Wheel off my 35.5 Legend today. There was corrosion around the block on aft portion of the wheel where the cables attach to the wheel. There was more corrosion in the bolts holding the drive wheel together. In the process of removing the wheel there were cracks in the wheel casing itself. I am in the process of talking to Edson now to get a new wheel.
Here are pictures of the rudder post where it enters the cockpit. There seems to be a missing cover that goes on top of the yellow gasket. I do not know what it looks like but you can make out the outline in the sealant on the deck. I have an email into Hunter Owners to see if they know anything.
Also the rudder shaft/post is hollow and seems to be holding water. Is that normal?
Thanks
Steve
I will be replacing the chain and cables as well as the throttle and shifting cables.
Thanks
Steve
