Easylock
542
Hunter 33 Seabrooke, Houston
On the cabin top, next to the winch, on my H33, there is an Easylock rope catcher (I am certain this is not the technical word) for double halyard; They cost $170. 00 which I think it is highway robbery; my question is this:
The place where it screws on to: is there wood under?
Could I use a similar device, but for a triple halyard, that cost me 10 times less and is in perfect condition?
No place to get to inside the boat, so I assume these are self tapping machine screws that secure it.
Should I fill the holes with epoxy and drill new holes, or am I stuck with thae broken unit?
The distance between the mounting bolts corresponds with what is for sale, so could I use a different unit?
The same applies to the winch right next to it: it is broken; can I drill new holes and install a different winch?
I got self tailing winches, like new, for $ 50.00 but that is not what they cost elsewhere
Thanks for helping. I will figure out how to put pictures for Sam,Ed & all the others that are just as happy to see me doing good as I am
Dec 2, 1999
15,184
Rope Clutches?
Jorge: Check out Garhauer Marine. The make this stuff at reasonable prices.
If there are machine screws holding your hardware down, then there is an alum. plate embedded in the fiberglass. This would require drill and tapping to secure any new hardware. You can probably use one of the screw holes and just fill the other with caulking. There is no need to epoxy the hole if the new hardware is going to cover up the existing hole.
The triple is $155
www.garhauermarine.com
Jun 21, 2007
2,118
Agree with Steve most likely you've got an aluminum plate under the area where the rope clutches and cabin top winches are. Shouldn't be a problem using a tripple clutch as long as you've got enough space. Important though that you mount/orient so that the halyard still has a straight shot without a bend. Also give consideration if there are other lines that you might want to lead to the clutch. Determine the screw diameter and thread pitch that already mounts the exiting clutch. Then any hardware store will have a matching tap for new SS screws. Cut threads in the top fiberglass and into/through the aluminum plate after first drilling with the matching drill bit for the tap size. On my 1980 Cherubini H36, below the aluminum is a appx 1/2" air gap, then the interior liner. When you drill through the aluminum, the bit will fall suddenly and hit the liner. DON'T drill any further unless you want to see a hole in your ceiling. Go slow and steady when tapping, backing off the tap frequently to clear the cuttings. Once, I was distracted when tapping for a new rope clutch and twisted the tap off center. It broke off in the hole. The tap metal is very hard, but also very brittle. Also use some oil to keep the tapping process lubricated. It really helps. Caulking should be used for all the holes. It helps to put in a bit of a bevel into the cabin top gelcoat at the top of each hole. (Running a larger size drill bit backwards works OK). When you tighten the screw and the bottom clutch face tightens against the cabin top, the caulk compresses into the bevel.
So where do you find $50 self tailing winches? Even beat up used ones are expensive in my area.
Jun 25, 2009
542
Thanks for the advice on how to drill this thing: I will follow the instructions to the letter
There is a salvage yard in Houston where I found an identical Hunter that I scavanged clean; there are about 30 sailboats, with great winches, self tailing among them
I think I was the first customer they had, and I have worked out a few good trade deals with my doors (I am in the door business)
I needed a stern rail, paid $ 35.00; needed winches (normal large ones) paid $40. each; needed hand rails, $10 each, I need a starboard toe rail (mine is damaged at the ster for about 1 foot) and I can get the complete one for $ 100
The problem is to remove it, I think I will use a angle grinder
Got a nice 3 blade prop for $35, Richie compasses for $40 and so on
You can contact me by phone if you wish at 281-728- 9035
Tried to post some parts available, but it got removed, don't know why; I was only trying to help fellow boat owners, not for profit, but so that everyone has a shot of restoring his/her boat and not get screwed from some of these sharks out there
May 31, 2007
784
Hunter 37 cutter Blind River
I mounted clutches on my H33 several years ago. I do not recall there being any plate material in the deck anywhere - and I recored just about the whole damn thing. There are raised up rings molded in and they are for mounting things like winches. The have a think piece of plywood molded in over the balsa. I would follow generally accepted procedures for mounting this stuff. i.e. drill out mounting holes then use a bent nail in a drill to route out a cavity in the balsa. Fill with thickened epoxy. Redrill and go through the liner. Drill a one inch hole in the liner. Now you can mount your gear on deck, bedded in compound, and apply backing washers and nuts between the liner and bottom of the deck. You can get little round white "buttons" to fill the holes in the liner and the whole result will be unobtrusive.
Jun 25, 2009
542
Sandpiper, do you mean drilling all the way through into the ceiling of the boat, on the inside?
And if I tighten with washers there, is it not going to crack the fiberglasss ceiling, when I tighten the nuts?
I think I am missing something here...
Jan 2, 2005
779
Hunter 35.5 Legend Lake Travis-Austin,TX
Jorge, I'm interested in the "salvage yard" you mention. Where exactly is it and how many boats are still available to scavenge? I'd be interested in larger winches, Lewmar and Maxwell 33 or larger, and possible Yanmar engine parts, whisker poles, cleats, ladders, or who knows what. I may call you in the next day or so if no response.
Jun 25, 2009
542
Salvage yard is in Houston
10 more boats are arriving in the next few days
Phone me at (281) 728- 9035 for more details
Lots and lots of cleats, poles, etc and ladders too
Happy to help
5,802
Jorge, it is as Sandpiper describes. You need to bolt through the headliner. You can do as he suggests and countersink the washers and nuts on the inside and then cover. Or as I did with my two deck organizers, just big stainless fender washers and nuts exposed. I am ready to add a starboard side winch and clutch and will do it that way. The look might be offensive to some but to my eye it is fine.
The one winch on my cabin top is bolted through and then has a round teak block glued over the bolts. Came from the factory that way.
Jun 25, 2009
542
Ed,
Do you mind sending me a picture so I can see how you did your deck organizers, with the bolt and washers exposed?
I have a winch also, starboard side, a bad one; then to the right I have the easylock (also bad) which I want to remove and replace.
Thanks,
Jorge
Jun 25, 2009
542
I read Sandpiper's comments again, and I think I see light at the end of the tunnel (I hope it's not the train)
Seems clear now that I see he wrote 1 inch hole and bed hardware between the liner and the bottom of the deck.
What kind of white caps do you mean to make it look pretty again?
Jorge
Jun 25, 2009
542
Tomorrow Friday I am going to the salvage yard
Please give me a shopping list before I go, so I can get prices and pictures.
I believe 10 more boats are arriving
For me it's not for the profit, but a pilgrimage almost every Friday for 10 months, since I got my H33
Freight is the only cost I need to recover, got a sail last week for $ 100.00
Jibs, unfortunately, only for smaller boats, and main sails also, but no jibs
Anyone has one?
Nov 8, 2007
1,618
Similar work on an h27
Here is my project on our h27:
http://hunter.sailboatowners.com/in...7&cat_id=16&aid=7355&page=article&mn=27_75-84
There are no aluminum backing plates on our boat, so I drill-fill-drilled all of the holes and mounted through the liner with fender washers. Then I covered all the ends with a piece of cherry with a teak grab-rail mounted on it.
The liner on our boat is flexible enough to be tightened against the deck without cracking or other issues.
By the way, I got the winch, cheek blocks, and organizer for free from a friendly rigger who kept a grab box of stuff he had taken off other boats.
5,802
I remember that David, nicely done. I assume that is your main halyard. I have all the hardware ready to do the same. Just wondering how much extra effort that you notice compared to working at the mast.
May 31, 2007
784
Well my earlier comments have drummed up some questions! I always like shaking things up. First, the answer is yes. A small hole through the deck for the fastener bolt. A larger hole, like 1", through the liner to provide access to the nut and washer end of the bolt. Very difficult getting a washer and nut onto the bolt while someone on deck holds it down. The trick is to put a little caulking on your index finger then stick the washer to that. By feel, the owner (the one down below - you wouldn't give this job to a friend) slides the washer onto the bolt then removes finger. The washer usually remains in position, being held by the caulking stuck to the bolt threads. Repeat the process with the nut while the helper on deck slowly turns the fastener. You can just get a socket or box wrench into the hole to tighten the nut. Better turning the nut than rotating the bolt on deck as the latter may auger out some of the caulking which is supposed to waterproof the whole deal.
On the H33 it was necessary to use this method rather than bolting through the liner and making a double decker (pun) sandwich because the space between the liner and deck is MUCH greater than on the H37C. The bigger boat seems to have the liner almost bonded to the deck. Be sure to have lots of spare fasteners. I am sure that if the current owner of my H33 were to cut the liner completely out he would recoup the purchase price in stainless washers, nuts and lost wrenches! And keep lots of rags around and a garbage bag very handy. The owner will end up with more adhesive goop on him than the boat will hold.
Ed S - good try on those plugs but they are not the ones that will work on the 33 liner. CS yachts and C&C used to use these to cover screw heads and they worked well. However, they won't fill a hole. I get mine from The Rigging Shoppe in Toronto and haven't seen them elsewhere. Too bad. They consist of a disc larger than the hole to be filled and a perpendicular cylinder which grips the liner hole. Unfortunately I do not have access to any right now so can't attach a photo but if I am at that chandelry this spring I will get at least one, just so I can more effectively share with you.
