You don't suppose that when switching from 110v to 12v that the compressor had to start aginst too much head pressure and that is the reason for the big start load.
Might try switching over after the frig has shut down on it own and had time for the compressor to bleed down befor switching to 12v.
"I went back to the boat yesterday and did a little snooping around.
The fridge was running on AC. It showed about 33 F. so it was near shutting down, but was still running. I plugged in the 12 volt, then unplugged the 120. It shut down just like I thought it would. This time, instead of trying to get it to start, I just waited. Well it took maybe 3-4 minutes and it started up on its own.
I feel better about that now. I guess it just takes a few minutes for it to make the switch over??
Amp draw still went to 7 or 8, and volts dropped to 11.8 from (I forgot. 12.8 maybe). I pulled the plug and found the end was hot enough to burn if I kept touching, so I cut the 12 socket plug off and attached a 3 ft #10 extension, and wired it direct to the battery.
