Mickey Goodman
I have a 1988 Legend 37 which has a 1" bronze drive shaft.When I have the engine in gear and traveling at low RPMs I find that the drive shaft is shaking quite a bit between the strut and the stuffing box. My guess is that the shaft might be bent. I have made sure the alignment of the shaft connecting to the transmition is correct. There is only 225 hours on the engine so the engine usage is low.Two questions: 1. I can't remove the coupler end from the shaft which connects to the engine. I have used a puller which doesn't make any movement in the coupler. Is there a trick in removing the coupler from the shaft? 2. Once I get the coupler off and find the shaft is not bent, where can a get a stainless steel replacement shaft without getting ripped off from the marina?Thanks for your help.
