I am in the process of stripping the bottom paint off of my trailer sailor hull (Oday 192, 1988) and was planning on applying a barrier coat. Scraping the older, blue bottom paint is quite easy and I expected to see white gel coat below. However, I have encountered this brown/tan mottled layer that is very smooth and harder than the blue bottom paint. But I also see white hull in some locations (pics attached). I do not know what this mottled layer is. Would a previous primer be so smooth and hard or would this be an actual barrier coat? I would like to figure out what it is in order to determine what type of layer I should put over it, or if I should strip this layer as well. Has anyone encountered such a layer? The PO is not available for info. Thanks, Robin
