Dodger Windshield Cleaning
Dec 19, 2006
5,812
Hunter 36 Punta Gorda
Here in Florida I keep the dodger windshield panels zipped out for more air flow but last week was one of a few times we put them back in due to the very cool 20 to 25 knts of wind we zipped them in but than it was very difficult to see out in front while motor sailing down the ICW.
Aftering info on FLITZ and polishing & buffing ball I gave it a shot and it did make it better but not as clear as we wished.
I tried some Meguiar's Plastic X and it was amazing how much better it cleaned the plastic windshield so much clearer and even removed some bad marks also.
I was thinking that we needed to replace the clear plastic windshield panels but not any more and can't wait to put them back on and see how good they will be looking out through them.
Nick
1,862
Yeah amazing. My dodger is 6 years old and the canvas guy told me to clean eisenglass only with fresh water and a soft cloth. Well, just before hauling I bought some Star Brite stuff and did the whole enclosure eisenglass. It was amazing. Looked like the day it was installed. Clear and glossy. Maybe the canvas guy is a little out of date.
Oct 14, 2005
2,191
First I would clean the windows with dish detergent in a mild soapy water solution. Don't use a product like "Windex" to do the initial cleaning as the alcohol base will deteriorate the plastic.
When dry, I originally used convertible top window cleaner from my old sports car days. When it ran out, I started using the headlight lens cleaner stuff over the winter a few seasons ago. Lightly applied and followed up with a good light waxing (not "cleaner wax") and my dodger windows would stay clear for the almost the full season.
Nov 25, 2010
50
hunter 35.5 catawba island
Many years ago Grady White (a power boat company) recommended using acetone. It worked very well and I kept my eisenglass very clear for over 15 years. If it were not for the company's recommendation I would never have otherwise tried it because I know it will cloud some types of plastics.
Feb 6, 1998
11,675
Are you sure it was Acetone and not Denatured Alcohol?
I know for a fact that Acetone will damage, cloud & distort Eisenglass, AKA clear vinyl, AKA clear polyvinylchloride, AKA clear PVC.... Ask me how I know.........;);):cussing::cussing:
Acetone will 100% void the warranty on Strataglass and will physically melt it. Strataglass is also clear vinyl...
BTW Acetone is used as one of the major ingredient the "PVC cleaner" that pre-melts/cleans PVC pipe before the cement is applied. PVC is polyvinylchloride......
Nov 25, 2010
50
I am positive sure. I used it hundreds of times. Strataglas may be different. I tried it on hard plastics and on some it did not work well. I know it seems wrong but it is not. I used to get black marks where the stainless rubbed against the eisenglass and the marks wiped right off. The eisenglass out lasted the canvass and stayed clear and pliable.
Mar 26, 2011
3,424
Corsair F-24 MK I Deale, MD
I am up to about 40 panels test panels. Some testing cleaning rituals, some polishes, some scratch removers, some protectants. I've learned a few things for certain and will learn more before we finish in ~ 3-5 years.
a. Mainesail is right. Just for laughs I went downstairs and dunked some Strataglass in acetone. While it doesn't melt it right away, it softens sufficiently that any cloth will leave tracks. Additionally, commercial acetone often contains traces of other solvents. In time it will also remove the polyurethane coating which, among other things, prevents humidity induced hazing. While it is possible to get away with under certain circumstances, it's Russian roulette with 3 bullets. Perhaps the poster had just the right window, just the right solvent, light application and good luck, but I don't see it.
b. Alcohols present a similar risk one of the big gambles is whether they have added a little denaturant or MEK for increased solvency. A big gamble. Hardware store solvents are a crap shoot at best.
c. Cleaning with any abrasive containing polish reduces vinyl life and increases humidity haze. They cause million of micro scratches, and while a wax can hide them, the waxed test panels still haze, just a bit less. Don't do it. Instead, either use Imar products like the manufacture tells you (they are very good and very safe) or at least use a non-abrasive product and elbow grease (with only VERY clean cloths). I have the screwed-up panels to prove this. Yes, cleaner products are faster and look good in the short term. Perhaps for old damaged vinyl it doesn't matter so much. Perhaps for folks in climates without nor'easters won't notice so much.
d. The best way to ruin vinyl fast is to spray them with bug juice, sunscreen, or water repellant. Some of the solvents literally melt the vinyl and many can ruin the window in a single application.
And I should probably leave it there. While we may discover some additional safe cleaners and protectants (in addition to Imar), so far I'm pretty certain that Mainesail's vinyl maintenance tips--basically manufacture guidance--will remain the gold standard; keep them clean, treat with protectant, don't scratch them, and use only approved products. I've met with the makers and they have some horror stories to tell. Don't be one.
Good luck!
Feb 6, 1998
11,675
Good luck!
One word for dodger glass care..... IMAR
Apr 11, 2010
950
Hunter 38 Whitehall MI
I only use IMAR on recommendation from our canvas maker. He said warm soapy water with microfiber cloth followed by IMAR.
Nothing else EVER he said.
It's worked for me.
Dec 19, 2006
5,812
Good
I guess I did not take care of my clear windshield as I should have but did use
IMAR products for cleaning and protection over the years but I guess it took
alot of wear and tare and had some real bad marks and this last year or so tried using Imar for cleaning it up but no luck and almost decided to replace it with new.
But before replacing it gave it one last shot and was very impressed with Meguiar's Plastic X and the Flitz both with the buffing ball but the Plastic X really did make it like new and can now see out the windshield much better and will use the Cleaners I have from IMAR.
Nick
Mar 26, 2011
3,424
The ironic thing is that zipping panels out and rolling generally increase wear rather than reduce it. Clear vinyl prefers to hang in place. Practical in Maine, difficult on the Chesapeake, and impossible in Florida.
I've had great luck covering windows, which may make god sense for you, with the UV, depending on the wind and how you do it. Covering windows has not worked in Maine, with less UV and more wind; polishing is obviously working well there.
http://sail-delmarva.blogspot.com/2013/09/to-cover-or-not-to-cover.html
Sep 15, 2009
6,243
S2 9.2a Fairhope Al
Nick
they way i view this problem is that when they are new and in good repair treat them like the manufacture recommends to and when that no longer works(after several years of use and in the hot bright Florida sun light) its time to bring them back to life and do what you have done...only thing is when that happens it will more than likely have to be done more often as time goes on.... so when that gets tiering replace them and wait till that time when the cycle has to be started again......based on your description you have done the best you can and also a good job at that ....
regards
woody
Feb 6, 2013
437
Hunter 31 Deale, MD
I just sold a 37-year-old sports car with its original convertible top. The plastic windows were crystal clear. Wash your windows gently and thoroughly and polish them with chrome polish.
I should point out that the car was garage-kept. So you will probably want to apply something to your windows for protection from the elements.
