ok.... Might I 'ASSUME' all your seacocks are closed? If you close them all, the two suspects left would be a damaged drain plug (mine has been glassed over for just that reason) or the prop shaft packing/grease fitting tube is dripping heavily. Someone else here mentioned he had to grease the fitting after each time he ran the engine.
If it's not one of these you need to pull the boat and fill the bilge with water and dye to see where the leak comes out. Good luck!
John
John
