Do I need the Halyard Restrainer??
Sep 3, 2011
59
O Day O Day 28 Michigan City, In.
This is a photo of the top of my mast on an Oday 28. With the new Roller Furling Sail I have do I really need the Halyard Restrainer to prevent Halyard Wrap of the Forestay? I know the Sail will stretch in time and the Harken Restrainer I have in place now as seen in the photo will either need to be moved up or do I really need it considering the amount of Furling tube exposed at the top of the forestay. Any opinions?Roller Furling and Mast Head..jpg
Have you read the Harken website? IIRC, it discusses the preferred/necessary angle for the restrainer.
Sep 3, 2011
59
Stu,
Yes I have checked the site. The angle of the halyard would be parallel with the forestry which is acceptable but the best is with a halyard restrained. With a distance of just under 6 inches do fuller tube shown and future stretch of the new sail I was just wondering if the restrained was necessary. if you look at the photo the halyard is almost two blocked right now. thank you for your reply.
I understand. Is that a snap shackle up there? If so, you might want to reconsider and use a D shackle, smaller and could get you more room and be more secure. Do you have any "wiggle room" at the tack?
Dec 2, 2012
46
Pearson 39-2 New London
I pulled my mast and replaced all of my standing rigging when I purchased my Pearson in 2012. The rigger suggested I replace my halyard restrainer as it was very worn due to my wire jib halyard, so I did some research. I came to the conclusion that it may not be absolutely necessary, but it is designed that way for a reason. The halyard lead just didn't seem right for my roller furling without the restrainer. Just my opinion, but it doesn't seem like an expensive enough part to skimp on.
Sep 3, 2011
59
Stu,
Great idea using the D Schackle. I never thought of that. It should get me 2 more inches. Thank you.
Nov 3, 2010
564
Oday 39 Lake mills WI
I'm thinking over the same issues. I bought my boat with a new harken furler on it and an assortment of sails that were never cut for thIs boat. A restrainer was mounted very low on the mast , likely due to a short sail . My current sails came from a sister ship who's owner is a performance cruiser. I just called him last night about removing the restrainer. He says get rid of it but I'm concerned the my fulling unit is lower than his.
I hope to never experience halyard wrap . Harken says it's the worst case scenario .
I plan on moving the restrainer up 4 or 5 inches and see how the luff looks. I'll consider re-routing the halyard out board if I'm not happy with the luff tension.
I am vary concerned that the angle will never be large enough with out the restrainer so I will likely keep it but move it up a bit.
One last word from Harken. They recommend restrainers for all charter boats regardless of geometry . I like fool proof so I guest I like restrainers.
