Dismasted
Dec 14, 2015
5
Humter 430 Key West Floida
Fellow Sailors~
We lost the mast and standing rigging off of our 1995 Hunter 430. Need a replacement. Any and all suggestion welcome.
Thanks so much
Stranded.
capta
Jun 4, 2009
5,006
There are a few big yacht salvage yards around New Orleans and they probably still have masts from Katrina.
Likes: c. t.'s
May 24, 2004
7,202
CC 30 South Florida
The circumstances might be secondary, if you have insurance it might be covered under an accidental occurrence. We had it happen to us on a 1985 boat about 8 years ago and they not only covered it but determined a new spar was in order. They recommended a rigger and he ordered the spar and all parts.
Likes: c. t.'s
Dec 19, 2006
5,832
Hunter 36 Punta Gorda
I was told about a very big salvage yard near the catlina factory in Florida and only
heard this from other sailors but never been.
Nick
Likes: c. t.'s
Sep 8, 2014
2,551
Hopefully you were able to salvage your boom/hardware and retrieve all of the hardware from the broken mast... That will save you time, money, and a big headache. Keep in mind that you could find a spar section that was not OEM, but is a similar spar section. Shorter is no good, but longer can be cut to the correct length. Its not so simple as it sounds, since there will be screw holes for hardware and spreaders that won't match up if a different spar is shortened, but it is possible.
JamesG161
Feb 14, 2014
7,931
Hunter 430 Waveland, MS
Since that Model is same as mine, I would be interested how it happened?:wahwah: Accident or failure? Mine is Z-spars ≈52 feet in-mast furling main.
Jim...
Likes: c. t.'s
May 4, 2005
4,062
try sailorman in ft laud
and
Marine Connection Liquidators
in ft pierce.
+ post a wanted in Craigslist
GL!
Likes: c. t.'s
Dec 14, 2015
5
Jim...
R & B traditional mast, not furling. Turnbuckle toggle failed.
JamesG161
Feb 14, 2014
7,931
You should get a very very good rigger with B&R rigging experience. Pre-Bend and head sail force compensation is "strange" to many. I will inspect mine with a magnifying glass for fatigue or crevice corrosion. Failing backer plates may have caused buffeting too.
It would be nice to keep the forum informed of your progress.
Thanks...
Jim...
Likes: LloydB
Aug 2, 2011
90
Newport 30 MKIII Madeira Beach, FL
A little late replying, CT. Don't know if you found a mast. Catalina Yachts in Largo, FL, (727)-544-6681 has masts in stock. Most are extrusions only, some rigged, but they also have a mastheads, spreaders and brackets etc. Possibly they can help you.
-na -NA Anywhere USA
First, C.T. is your mast a Z Spar and if so, you might want to see if this forum can arrange something working with U.S. Spars out of Gainesville, Florida. Z Spar without going into it, pulled out of the country and now the extrusions, etc. that US Spars sells is actually the Z Spar. Catalina at the time had their own masts made which the spars were much different. Catalina and Hunter now use Selden Masts.
When using a different mast by purchasing a used one, there are many things to consider. First the mast step and associated hardware have to be considered if compatible. On some boats the mast step is not as easy to remove and you need to notice the height of the mast step off the deck as one consideration. Placement of the spreaders is another as the spreaders have to be angled backwards and the list goes on not to mention the all important lengths of the standing rigging because one mistake and then you are into big bucks. Then a used mast, I personally would give it a close inspection to make darn sure there is no damage because you would need to know why it is used and sitting in a salvage yard.
The suggestion to get a rigger is a good one. I cannot remember his name and the name of the company but in Florida there is a rigger who used to be the manager of the US Spars location in Gainesville and he knows the Z Spar and US Spars all too well. It mighty behoove you to find out who that is as you are dealing with a B & R rig which does not require a backstay.
The Hunter 430 is a big investment and find it odd as to why you have no insurance on the boat. Aside from repairs and contents, is it really a big risk not to have at least liability on that boat in the event you are in an accident or incident where you wish you had insurance or run the risk of loosing everything you own. I use to be a Hunter and Catalina dealer not to mention a former military pilot but also an adjuster but later investigator for insurance companies just pointing out some things to consider . As for Craigs List, just be careful.
Nov 8, 2010
11,386
Sadly, no insurance.
Not to rub salt into any open wound, but how is that possible?
Lets the the boat cost you over $100k. They list for that now. If you took out a mortgage on the boat the finance company would require mandatory coverage. If you wrote a check, what was the thought process that led you to not insure it? Is there some crazy set of circumstances that transpired that others can learn from? Again, really sorry for your loss; hope you get sorted soon.
JamesG161
Feb 14, 2014
7,931
My Hunter 430 1997 has Z-Spars. I understood him to say turnbuckle failure on a side stay. Perhaps the Z-spars mast is ok.
I hope so.:(
Jim...
PS: BTW US-Spars is a good company. They have been very helpful to me. Ask for Brandon or Mike.;)
When a mast falls, then a close inspection is needed. I doubt it survived but thank you for advising which mast. Keep us posted. Since you know the fellows at US Spars that is a good start.
