Dinghy repair glue
CYQK
Sep 11, 2009
606
beneteau first 42 kenora
Need to fix a spot on my inflatable
What is the best glue to apply
THks
colemj
Jul 13, 2004
1,123
Gflex for sure on hypalon. Better than the special glues. I'd also say Gflex for PVC, but @dmax implies not to.
Is there a reason not to use it on PVC? I have repaired a PVC inflatable SUP and inflatable wingfoil board successfully with it. Both of them blew out seams that were reglued with Gflex.
Mark
dLj
Mar 23, 2017
5,152
Mark
@dmax I'm also interested in the answer to why not use Gflex on PVC. I've used Gflex on PVC with good success. I rebuild the stern of an ocean kayak that had suffered a lot of damage in a storm, tore out the stern rudder and ripped a large hole in the stern. That was a structural repair and as far as I know, it's still working fine after a number of years.
Maybe the suggestion was that the 2 part polyurethane is all that's needed and the Gflex is over kill? Not sure.
dj
dmax
Jul 29, 2018
1,343
Telstar 28 Buzzards Bay
Sorry - I haven't used G-Flex on PVC but I'm sure it would work, it's amazing stuff.
Likes: dLj
capta
Jun 4, 2009
5,088
Over the decades, I think I've tried every possible way to fix, or mount things like lifting points on inflatables, and never found anything better than Epoxy 330. However, it really is all about preparation. Super clean (not even fingerprints), sanded through any shininess on the repair/installation area and the patch, I've even used lighter fluid to insure cleanliness.
Tiny to small holes can be fixed with the smallest patch that will cover the hole, whereas larger ones will require more area around the damage.
I've even repaired transom problems with the 330, and for a "field repair" it worked very well.
