Stu, If I'm single handing at sea and I see or smell 'burning', I want the engine shut down now
without leaving the helm.
I don't disagree at all.Stu, If I'm single handing at sea and I see or smell 'burning', I want the engine shut down now
At least on the 3JH2E the pull is about 3 inches
Don, I was down at the boat and decided to take some poor and hard to see photos of my shut-off solenoid. Very hard to see but the rubber bellows you see is on the solenoid and the cable runs to the injector pump. Moving it by hand I would say 2 1/2 to 3 inches. Solenoid is mounted off one of the starter mount bolts.Which model Yanmar? Are you certain you have a Yanmar, all the Yanmars I have seen are gray.View attachment 220824View attachment 220825 Don, I was down at the boat and decided to take some poor and hard to see photos of my shut-off solenoid. Very hard to see but the rubber bellows you see is on the solenoid and the cable runs to the injector pump. Moving it by hand I would say 2 1/2 to 3 inches. Solenoid is mounted off one of the starter mount bolts.
He said he has a Perkins with a solenoid.Which model Yanmar? Are you certain you have a Yanmar, all the Yanmars I have seen are gray.
I don't think you have a solenoid.
Yes. It’s the same system on my Perkins. The solenoid pulls the wire, there is a spring that returns the fuel cutoff after the engine stops.
I see. The OP has a Yanmar. The thread has become a bit confusing when a question is asked about a Yanmar and responses to the thread talk about another brand.He said he has a Perkins with a solenoid.
Just for any future passers-by of the thread - the YM series has a stop solenoid and it is not common rail. It is a relatively new model though.Yanmar's do not have a solenoid for shut down, the fuel system is entirely mechanical, at least for the older engines that are not common rail.
Agreed!I see. The OP has a Yanmar. The thread has become a bit confusing when a question is asked about a Yanmar and responses to the thread talk about another brand.
That would certainly make it easier to follow.The OP asked about a Yanmar, let's stick to solutions for a Yanmar.
You said that much better than I did John. If my hand can pull the wire then a solenoid can pull the wire. Doesn’t matter what make of motor.The solenoid pulls the wire that is attached to the high pressure pump lever.
