Depthfinder doesn't
Jim
Just bought a 1988 c-30 and found that the depth finder only occasionally reads proper depth...mostly it just flashes "2.2". Anyone seen this, or have ideas what to check. Should the display unit be brought in for service or is it the transducere? I checked the cabling to the back of the unit and found that their was a slice in the coax about six inches before connector. Thanks in advance! Jim
Jim
splice...not slice
splice...not slice was found in the coax about six inches from the connector in the back of the display unit. sorry for the typo.
Stan Rogacevicz
It May Be Confused
Jim, If it was only happening occasionally in sheltered waters it is sometimes caused by sediment or other stuff being suspended in thermoclines. The Raytheon gauges seem to pick 2.2 to display when they are totally confused. It was typical for me to see that in late summer in the Greenwich area of NG Bay. If you are seeing 2.2 mostly everywhere you go I would suggest diving down and cleaning the transducer with a stiff brush. If you don't use "transducer anti-fouling paint" you probably should. Stan "Christy Leigh" c320 #656
Roger Fleming
Me Too
I have an '85 Cat 27. It has a Signet Marine, System 1000. I'm having about the same problems. I seem to be getting good readings (sometimes) in water 15 feet or less.
G
Gary Nickel
Sent mine in
I sent mine in with out the transducer. Should have. I reinstalled and it worked in deep water but not when I came back to the marina. ( Clean transducer and adjust gain control) Good luck Gary
James Taylor
Transducer in water?
I have a Signet depth sounder that is not through hull. The transducer must be in water to read correctly. If it's not the readout flashes 18.8. Maybe your is also like this.
