I recently purchased a Catalina Capri 18 wing keel. When I went to launch at my local ramp, even with the trailer tongue fully extended it seemed pretty far from getting deep enough to float off the trailer. My tongue retracted is 56 inches, extended 80 inches (so extending the tongue adds 2 feet). I measured various points against the hull to estimate how deep the water should be to float it off the trailer, but I’m not sure which measurement is the right one to use. Against the hull immediately by the keel is 35 inches high. Where the hull begins to curve up to the side is 40 inches. Above the lower stripe on the side is 46 inches.
I took some measurements this morning and to reach a depth of 50 inches I need to be able to reach 423 inches past the ramp waterline. With the tongue fully extended and vehicle backed just before water reaches the exhaust, it’s 165 inches. So that’s an additional 258 inches (21.5 feet) that I’d need to extend enough so the boat will float.
Does that sound right? If so it seems my only option would be launching with a tow strap. On that subject, can the tow strap connect to the tongue fully extended or does it have to connect further back? Presumably I’d need to add a tongue wheel rather than relying on the jack wheel right?
