As long as they are separated inside your boat.............only thing i have reservations about is the neutral being one and the same on those outlets..........
Those come in very handy when you're visiting other marinas. Sometimes I've been placed on commercial docks where all there is are 50A service boxes. In many cases, we can rent them (no cost) from the harbormaster, like in Half Moon Bay. Splitters and Ys get too complicated for me.and 50-30A converters.....
what do you suggest ...my thought was to to plug in the shore power cord to the gensetWhat is the plan for grounding the Honda generator AC service?
How on earth do you need more than 30 amps? I have AC on a 34' cat (we are discussing 30' mono) and never draw more than 16-17 amps, even with the lights on and the charger drawing. I've used a single 30a for over 10 years with no issues.ok it's getting hot down here and i have onboard ac .....now it is wired in the the maine panel...via a 30 amp single breaker on the acv panel......i am wondering how to add an extra shore power cord through a new 30 amp deck fixture ...that's the easy part...but when i feed the power to the panel should i treat it like a maine breaker on its own or can i wire the hot leg to the single pole breaker and connect the neutral and ground to the buss bars that are in place now granted i isolate the breaker from the grid in my panel or do i need to have an extra maine breaker in the panel on its own and then a single pole breaker from there to the ac ...its a power hog and makes it hard to run the micro wave and the other things at the same time...i do have an extra dock side outlet available ....i will have to check and see that the two outlets or not on the same hot leg at the dock
i don't need 30 amps total to run the ac ...the ac company requires a 30 amp breaker on the power feed....my dock power in the summer time gets a little low on voltage .......if i dedicate a power source to the ac only i will have enough to run the ac stand alone .....with a separate power source for the house panel i can run my accessories with out tripping out the 30 amp breaker here on the main panel ...if i try to run the ac and all the rest it will exceed the power limit ....my cooking will be interrupted and my boat will get hot here in the sunny south ....it takes about 13 amps to run the ac with the fan and the water pump along with the ac compressor...and that is about 50% of the power on the maine breaker and if you add in a microwave and a induction cooktop...hot water heater and battery charger you are using a lot of power ....mind you this condition is only at the dock ....on the water my creature habits are different...but at the dock i see no need to live like i am on the water....we are all victims of our trappings in one way or another....mine just happen to be at the dockHow on earth do you need more than 30 amps? I have AC on a 34' cat (we are discussing 30' mono) and never draw more than 16-17 amps, even with the lights on and the charger drawing. I've used a single 30a for over 10 years with no issues.
I would take a look at actual consumption, bearing in mind that certain things can't run at the same time.
there is a grounding lug on the genset for doing thatA genset is supposed to be grounded so that it can provide grounding to it's supply service - it comes back on the ground wire. My built in genset has the ground connected to the engine block. If you have a generator that is not grounded I would assume that any short circuit in your connected electric service could use you as the ground![]()
And the good news is, when your A/C shorts to ground and quits.. you will be rewarded with a basket of stunned fish!Gunni: Drop a ground line in the water off of the gen. lug? Chief
Yup, that is a bigger (or less efficient) AC unit than I have, and you have a whole lot of power-hungry AC equipment.i don't need 30 amps total to run the ac ...the ac company requires a 30 amp breaker on the power feed....my dock power in the summer time gets a little low on voltage .......if i dedicate a power source to the ac only i will have enough to run the ac stand alone .....with a separate power source for the house panel i can run my accessories with out tripping out the 30 amp breaker here on the main panel ...if i try to run the ac and all the rest it will exceed the power limit ....my cooking will be interrupted and my boat will get hot here in the sunny south ....it takes about 13 amps to run the ac with the fan and the water pump along with the ac compressor...and that is about 50% of the power on the maine breaker and if you add in a microwave and a induction cooktop...hot water heater and battery charger you are using a lot of power ....mind you this condition is only at the dock ....on the water my creature habits are different...but at the dock i see no need to live like i am on the water....we are all victims of our trappings in one way or another....mine just happen to be at the dock
