Dedicated shore power for onboard air conditioner ????
Nov 6, 2006
10,150
Yup.. Stu has it.. keep the systems separate between dock outlet and anything past that. The neutrals to dock service are together (on 60 ampere wire) until the breakers in the dock outlet.
Jun 6, 2006
6,990
One thing nobody has mentioned is what happens when you visit another port? There are numerous configurations that you will run into and your solution should be workable with a minimum of "extra shore power wiring parts" like splitters and "Y"s and 50-30A converters.....
Those come in very handy when you're visiting other marinas. Sometimes I've been placed on commercial docks where all there is are 50A service boxes. In many cases, we can rent them (no cost) from the harbormaster, like in Half Moon Bay. Splitters and Ys get too complicated for me.
I also have a 30A to 15A MALE. When we're rafted up or with limited shorepower outlets, it allows one of our friends to hook their shorepower cord to my splitter and I plug it into one of our 15A outlets down below. I just tell him not to run his water heater without letting me know! :)
Sep 15, 2009
6,244
S2 9.2a Fairhope Al
i have a honda e 2000 gen set that is the companion of the master one ...it has a 30 amp twist lock receptacle on it so i can just plug the shore power plug in at the bow and keep the generator away from the cockpit ....by wiring my air con this way i don't stand a chance of screwing up
Gene S
Nov 29, 2015
181
Delphia 37 Tacoma
What Bigeasy said. My boat had a/c but it was taken out. Separate transom socket to single double breaker panel and then to ac.
Gunni
Mar 16, 2010
5,937
What is the plan for grounding the Honda generator AC service?
Sep 15, 2009
6,244
S2 9.2a Fairhope Al
what do you suggest ...my thought was to to plug in the shore power cord to the genset
the ac circuit will not be in the mix...and i only intend to use the microwave and the induction cooktop and may be the battery charger and 750 watt hot water heater and not all at the same time
Gunni
Mar 16, 2010
5,937
A genset is supposed to be grounded so that it can provide grounding to it's supply service - it comes back on the ground wire. My built in genset has the ground connected to the engine block. If you have a generator that is not grounded I would assume that any short circuit in your connected electric service could use you as the ground :yikes:
Mar 26, 2011
3,840
Corsair F-24 MK I Deale, MD
ok it's getting hot down here and i have onboard ac .....now it is wired in the the maine panel...via a 30 amp single breaker on the acv panel......i am wondering how to add an extra shore power cord through a new 30 amp deck fixture ...that's the easy part...but when i feed the power to the panel should i treat it like a maine breaker on its own or can i wire the hot leg to the single pole breaker and connect the neutral and ground to the buss bars that are in place now granted i isolate the breaker from the grid in my panel or do i need to have an extra maine breaker in the panel on its own and then a single pole breaker from there to the ac ...its a power hog and makes it hard to run the micro wave and the other things at the same time...i do have an extra dock side outlet available ....i will have to check and see that the two outlets or not on the same hot leg at the dock
How on earth do you need more than 30 amps? I have AC on a 34' cat (we are discussing 30' mono) and never draw more than 16-17 amps, even with the lights on and the charger drawing. I've used a single 30a for over 10 years with no issues.
I would take a look at actual consumption, bearing in mind that certain things can't run at the same time.
6,244
S2 9.2a Fairhope Al
i don't need 30 amps total to run the ac ...the ac company requires a 30 amp breaker on the power feed....my dock power in the summer time gets a little low on voltage .......if i dedicate a power source to the ac only i will have enough to run the ac stand alone .....with a separate power source for the house panel i can run my accessories with out tripping out the 30 amp breaker here on the main panel ...if i try to run the ac and all the rest it will exceed the power limit ....my cooking will be interrupted and my boat will get hot here in the sunny south ....it takes about 13 amps to run the ac with the fan and the water pump along with the ac compressor...and that is about 50% of the power on the maine breaker and if you add in a microwave and a induction cooktop...hot water heater and battery charger you are using a lot of power ....mind you this condition is only at the dock ....on the water my creature habits are different...but at the dock i see no need to live like i am on the water....we are all victims of our trappings in one way or another....mine just happen to be at the dock
Sep 15, 2009
6,244
S2 9.2a Fairhope Al
there is a grounding lug on the genset for doing that
Nov 26, 2012
2,315
Catalina 250 Bodega Bay CA
Sounds like you have it figured out since you already have 2 power entry accesses on your boat. Chief
Gunni
Mar 16, 2010
5,937
You are on the right track with a dedicated supply for your A/C. Every year about November fellas start setting their boats on fire and burning up their neighbors too because they think a single 30 Amp service can run all their house loads. I really don't think our common Hubbel twist lock shore cord connections can safely take more than about 20 amps anyway. Mine see maybe 15 amps each and the plugs still feel warm.
So if you are going to use a genset afloat, you will want to use that grounding lug so that if something shorts out it doesn't light you up.
Gunni
Mar 16, 2010
5,937
Gunni: Drop a ground line in the water off of the gen. lug? Chief
And the good news is, when your A/C shorts to ground and quits.. you will be rewarded with a basket of stunned fish!
Mar 26, 2011
3,840
Yup, that is a bigger (or less efficient) AC unit than I have, and you have a whole lot of power-hungry AC equipment.
What puzzles me is that most of that equipment either won't work away from the dock or will smash you batteries fast. I don't understand electric cooking, water heating on a boat. But given the bed you have, you've got to lie in it. Be aware that you are probably headed for increased slip fees, depending on how charges are based.
I wonder if you would be money and cruising flexibility ahead to put the boat on an energy diet. It seems unlikely you have enough solar to sustain that load (without the AC) for even 2 nights away from a plug.
Sep 15, 2009
6,244
S2 9.2a Fairhope Al
that's what the honda e2000 is for...... cooking and heating water.....i also have a two burner gimbled alcohol stove top and a magma grill...
EDIT
this is my retirement years so just like the judge who told the man ...."you will support her in the manner in which she has become accustom to"........ i have worked all my life at one thing or another and now its time for me to do exactly what i want to without harming others...but mostly i am looking forward to meeting and making new friends
