deck fill caps
G
gk
i need to find a deck fill cap (diesel) for my cat 270 - can anyone help me with this?
Phil Decker
Haven't found 'em at West Marine
I have needed a new waste cap for my 1982 C27 for awhile. The size is in between what West carries. I can't figure that out. I don't want to have to install a new deck mount just to get a new cap.
L
LaDonna Bubak - CatalinaOwners.com
Might have to
Unless you can find a similar one by surfing the web, you might have to change it. Bummer. :-( LaDonna
Steve
Caps Avail At Catalinadirect.com
gk: Just ordered some for my boat. Go to Catalinadirect.com.
Dan
Had same problem with "in-between" size and didn't want to undertake removal of fill pipe...went to plumbing supply store and found excellent (albeit not identical) cap...works fine, looks good...for $6.00.
A
Andrew D.
Call Catalina
I had a deck fill cap crack a couple of years ago. I found a nylon plug at Home Depot that cost a couple of dollars. It did the trick, but it didn't look pretty, and it wasn't flush with the deck. I eventually called the Catalina parts department. They sent me a new one for about $20.
Dave Slepoy
deck cap "O" rings
Yearly I check the "O" rings on all my deck caps for cracks and wear. If you ever wounder why soapy suds end up in a tank or water in the fuel? The "O" rings do fail and when you wash the boat or it rains real jard you can get water in the tanks. Dave
