Dead Simple way to attach light objects to cabin interior
Aug 28, 2006
564
Bavaria 35E seattle
Much like Sail SFBay, we've used 3M command strip hooks that have worked great. The admiral's handbag weighs like an anchor and that holds up fine! I've held up a weighty fire blanket with one under the chart table across from the galley. The VHB tape is good up to several pounds, and obviously, the more you use the better the hold.
Dec 28, 2015
1,837
Usually the command strip plastic hook part that attaches to the stop fails/breaks before the actual stop fails.
