Dead inverter
Hunter 37 C sloop Punta Gorda FL
I'd ask around about other brands. The SW 2000 was so bad Xantrex quit selling it in less than 2 years.
Dec 2, 2003
1,637
Several reasons for a non functioning inverter and it may not be dead at all.
1) No DC power reaching it. Breaker tripped or fuse blown?
2) Too heavy a load on output side. See 3) below
3) Short on output. Disconnect all connections on output side, then put on a light load such as a mains voltage bulb and see if it lights.
4) Loose wire on DC input or AC output. Visual inspection.
5) Flat battery?
If all these quick tests fail then take it to a marine electrician's workshop for checking.
Jun 1, 2009
1,860
Hunter 49 toronto
Ok, I can help
It does have an internal fuse inside maybe even 2.
Nick
The Freedom inverter has 2 output fuses. You will need to pull the case to find them.
If it is not the fuses, then do the following:
Drill two 3/8" holes in the top of the unit.
Attach a beefy shackle,
Attach to anchor rode.
These are not worth repairing, and their cystomer support is very poor.
Buy the Magnum energy unit. You will live it.
Great charger/inverter, and the control panel is top notch.
You won't regret this
Jun 7, 2009
116
Hunter 1999 Passage h420 CC Oceanside
Yea, the inverter is getting go 13volts, the panel lights up, just no output.
I have had a few other look at it and even though the charger works, they thinkk the inverter is dead. It is 14 years old.
I think I will look at the Magnum energy unit.
Jun 7, 2009
116
Jun 7, 2009
116
______________________________
I do see that xnatrex stopped selling the older modle Freedom 2000 and now they are selling the 815-2012 and according to them they have resolved there issues.
Any thoughts?
Jun 6, 2006
6,990
PWM is pulse width modulation. Instead of pure smoothly changing voltage from 0-120 volts it breaks the changes into a lot of little steps over the same 1/60 of a second. Some devices with microprocessors don't like this kind of voltage, generally ones with PWM of their own which are counting on the AC for timing signals. Microwaves are a good example. Mine runs at 1/2 time when on the inverter. Still cooks well you just have to double the time to get to to run what you really want. Things with motors don't normally care unless they have speed controls.
BJV
Island Trader 41 foot Ketch, CC Arnold
We have two inverters, have a small Victron pure sign wave for our computer/peripherals. Went victron (even though pricey) as they have very strict EMI standards which is important for SSB operation. The advantage of having computer on inverter means its not affected by querky shore power.
Main inverter/charger is a Magnum Modified Wave 2500 with battery monitor and panel. Great unit, have had 0 problems for the past 5 years in a salt water environment. Wonderful customer support (needed help on instal). Very good reputation and good price if you shop around.
BJV
Other companies which have a good reputation are mastervolt and outback
Oct 24, 2011
278
Hunter Passage 450 Lake Lanier, GA
OK, I am taking a seriouse look at this inverter/charger.
MAGNUM ENERGY MS-Series Pure Sine Wave Inverter/Chargers ms2012.
With panel for about $1700.
http://www.wholesalesolar.com/products.folder/inverter-folder/magnum_ms_2012.html
Bob
I just purchased and installed this unit to replace my Freedom 2000 unit. You may want to look at Hodges Marine for a better price.;) Also unlike the Xantrex unit which is quite a bit bigger, the remote panel and remote panel wiring is a match to the old unit.
116
Well, I ordered the Magnum MS2012 2000 watt inverter 100 amp charger today with the remote control panel.
5 year warrantee all for under $1700.
It was a little more than the Xantrex, but with all the reports of reliability issues and customer service, I went with the magnum.
I will report as to the install once done! Hopefully by this weekend just after the 4th
Jun 1, 2009
1,860
Hunter 49 toronto
Not quite correct
Hi Bill,
Need to comment here .
PWM does indeed stand for pulse width modulation.
However, what PWM does us take a constant voltage, and chop it into small slices, varying in duty cycle.
Light dimmers use PWM, as the filament evens out the power curve by the stored heat energy in the filament.
The concept you are thinking of is "modified sine wave", where a sine wave is constructed of varying height dc levels. On a scope it would look like an up and down staircase.
Microwave ovens hate modified sine wave, as do other devices that rely on a pure sine wave for reference, and amplification.
Modified sine wave was used in all the Xantrex freedom series inverter/ charger units.
Getting onto the subject of this owner's issue, I highly reccomend the Magnum Energy unit.
Unfortunately, Xantrex customer service has gotten downright crummy, and I would not currently reccomend their products.
It's not only their cs that has been reported to be poor these days.
Jun 4, 2004
1,087
Mainship Piliot 34 Punta Gorda
I replaced my Xantrex with a Magum and highly recommend it. I ripped out the 1000 monitor and replaced it with the Magum as well. I have never had good luck with Xantrex equipment and would never install it on my boat, no matter how cheap.
Hunter 34 Seattle
Has anyone had any experience with the Xantrex Prowatt SW1000 Sine Wave Inverter ? I have a Xantrex modified sine wave 1,000 watt unit and thinking of replacing with one of these units. I use it as a stand alone system and have had no trouble over the past 8 years with this unit. Wanting something to power a low wattage microwave. I've heard some good things about this unit, especially the price.
