DC Electric Panel Fuse Question
Jul 24, 2020
8
Beneteau Oceanis 35.1 Annapolis
That’s what I am doing next. I forgot to bring the multimeter with me last time.
jviss
Feb 5, 2004
7,089
Tartan 3800 20 Westport, MA
I say this because I've tested piles of these outlets with FLIR imaging and 7.5A is what is safest and develops the least heat. 5A is even safer... I would not run any of them at 15A, not even the locking ones, especially after corrosion sets in or spring tension gets weaker over time. I also would never, ever suggest running a 30A shore power circuit at 100% of its "rating" but people do it and we have the boat fires and marina fires as a result.
Just circling back on this as I looked into it more. As you know I happen to like the Marinco 12V plug and receptacle. They are well made, and lock together very tightly, and are supposedly waterproof when mated. I have three sockets on hand, and only one plug left. So, I looked up the plug part number and ordered three more plugs - a bargain at arrow. com for about $4 each.
The plug, it turns out, has an integral 10A fuse, and the spec says the plug is rated at 10A. You could certainly put in a lower value fuse, like 7.5A, as @Maine Sail recommends, and have a safe connection.
Marinco 12VPG Spec Sheet
Likes: necochino
Jul 24, 2020
8
SOLVED: mystery solved. Replaced the 1A fuse for the Panel Light switch. That switch also turns on both the “cigarette lighter” adapter as well as the USB port i have just below it. Thanks everyone for your comments, ideas and humor.
Beneteau 323 Annapolis MD
... Replaced the 1A fuse for the Panel Light switch. That switch also turns on both the “cigarette lighter” adapter as well as the USB port i have just below it.
I wonder how long that one amp fuse will hold?
:plus:
I’m surprised they’d use a 1A fuse for that. Just charging a couple iPads could exceed that. Unless the 1A fuse only enables the circuitry, and there’s some other higher overcurrent protection in addition.
