DC Ammeter
C
Charlie
When I turn on our electric panel lights to illuminate the guages, the dc ammeter goes to the maximum current draw reading. Any ideas?
Ross
check the wiring circuits? The amp meter must be
connected in series with the supply line and there should be a shunt in parallel with the meter to give it the range you need. Try using a flashlight to look at the Amp meter and turn on on circuit at a time. Or just do it in the daylight.
Jim
How long does it stay there also
are you sure you are reading current and not voltage? Most boats have a DC voltage meter and not a DC Current meter.
That ammeter would be a 0-25, mabe 1-50A with an INTERNAL shunt
because it's DC load (for a "regular" sized sailboat). So either the wiring is snafu or the meter's toast.
GuyT
May 8, 2007
406
Hunter 34 South Amboy, NJ
Bad meter, bad load, bad wiring, bad karma..
No boat info.
No meter info.
No load info.
No history info.
Hmm, are you just looking for "any ideas" ??
