I have a Datamarine Corinthian II S400DL Depthsounder that started acting erratic (initially 4-5 times actual depth, then less, then - - - on the screen).
Any thoughts, as to the cause (transducer or unit) and if such old technology is worth trying to repair, is much appreciated.
I have a Raymarine I70 as well which I currently use for AWA and AWS only. Am I better off to just get the transducer for the I70 (I believe you can get just depth or depth, speed and water temperature in a single transducer for the I70).
Thanks for any input.
