Dangers of spinakers
MccNeo
May 11, 2014
55
MacGregor 26S Evans
Most cruisers have problem when they need to take it down in more wind than it when up in. That's mostly a practice thing. With practice you can take down a kite in ANY breeze. But until then keep a eye on the wind. As you go downwind you do not feel the wind building nearly as much.
Racers will have problems wiping-out in big breeze. This can be a simple round-up (ok), a round-down (bad), or a nose-dive (disaster).
It gets more complicated if you are trying to work out the details of snuffing the chute in a puff when the leeward mark is only 200 yards from the dirt bank. Then, it definitely gets exciting!
Apr 5, 2009
3,333
I use a sock also when racing and cruising because it simplifies the sets and drops with my short handed and inexperienced crews. I race so that I can introduce people to sailing and racing.
Likes: Timm R Oday25
Oct 1, 2007
1,865
There is no substitute for learning to sail on dinghys and small boats in general. I learned to sail on Snipes, Turnabouts, then later Ensigns. I owned two Ensigns and they were wonderful boats. Sailed in all weather and carried a Genoa and a spinnaker. In these smaller boats we learn the force of the wind and the power of a luff up in all weather. My favorite expression to my crew in heavy air was "...it's only noise...noise won't hurt you...". Everything I learned in small boats transferred directly to my cruising boats later in life. Another favorite expression of mine was "..if you can sail an Ensign you can sail a 12 meter or bigger....you trim the main in and they go to windward....ease the main and they go down wind..". In these small boats we learn to let the sheet run on the chute and turn down wind and she collapses behind the main. Works regardless of LOA.
May 20, 2018
2
Hanse 371 West Vancouver
I have a 37' sloop. I used to race and cruise with a symmetric chute (often single-handed) but eventually found gybing with the pole became dicey for me. (I am 76)
I switched to an assymetric (A2) on a harken furler on a selden bowsprit. It sounded like a great idea, but in practice it sometimes jammed when unfurling. I switched to an ATM snuffer which has never given me a moments trouble, and is faster than the furler which took many, many pulls to douse.
I can always get the chute down regardless of wind strength. I blow thge tack and snuff it to leeward of the main. A good autopilot helps.
Oct 10, 2009
1,118
Beneteau 393 Muskegon
I don't use my symmetrical Spinnaker because it just seems like a lot of work for where I am, normally just two of us in an inland lake with a lot of shifting winds and runs that are kind of short downwind. If I use the pole at all, it's to go wing on wing ddw in a race. That said, I think if you're careful and stick with light winds to start, it'll be ok.
I wouldn't mind giving mine a try, but the spin halyard would be the unused jib halyard, which is behind the forestay. Only time I've worked a Spinnaker, the boat had a dedicated spin halyard on a mast crane before the forestay- what difficulties would I face using that jib halyard?
Jun 14, 2010
2,486
I had an incident once with an ATN Snuffer - the control lines were tied loosely and had enough slack to wrap around the furler anti-wrap collar (the black device that controls halyard wrap at the top of the genoa). I couldn’t bring down the spin in a building wind and was running out of sea room. It was challenging to get them unwrapped from deck level, and the strong winds and rolling seas made it even more challenging. After that incident I have always been careful to keep both sides of those spin sock control lines tied off taught. Don’t let them flop around.
  • Helpful
348
Hunter 240 Okanagan Lake
Funny, I just learned I have a gin pole lol. I also have an asymmetrical spinnaker and a sock. I have no idea; you have to love it.
I will have my name in the hat for crewing in the near future on racing vessels. If I can drop this extra bit of weight, lol. I look forward to understanding all of what I just read. :)
I have tried wing to wing DDW on the Mac25. :) (That’s my best lingo :-D
Apr 5, 2009
3,333
One year, we had an Olson 30 that had a major snaffu in a race at the leeward mark before the final leg of a race that was too windy for me to hoist the spinnaker. FYI, there are serious rock about 100 yards past the mark so no sea room to sort things out.
I am not sure what happened, but the sheets and guys all ended up running free out of the blocks, with the spinnaker free flying from the masthead by just the spin halyard. The head of the sail was at least 30' from the masthead and the sheets guys were trailing after the whole mess.
Because they could not go any farther downwind without ending up on the rocks, they hoisted the genoa and turned up wind. They made good time to windward and finished the race. The Olson with spin flapping from windward was still faster upwind than my C30. There is a reason why the Olson 30 has a PHRF of 98 and my C30 has 195! I can guarantee that no one crossed anywhere near their stern because the sheets were wipe-cracking 150' behind the boat about 10' above the water. Quite a sight.
Apr 5, 2009
3,333
You can use the spare jib halyard for the spinnaker with several very important caveats. You must drop the sail from the same side that you housed it because if you are on the other jibe, the friction will cause problems. You also must keep an eye on the chafe that will happen where the halyard crosses the forestay. When I was gifted an undersized spinnaker to see if I liked it I flew it this way. I found that I needed to cut the halyard back about 6" every few sails because I would start to see some fraying of the halyard cover.
Likes: Indysailor
Sounds like a situation for the flare gun take down!
Jun 14, 2010
2,486
"Dangers of spinnakers" ???
As it turned out this thread belongs in the humor section of the forum. It's Funny Friday. :clap:
  • Ha
Likes: FastOlson
Oct 24, 2015
37
Hunter 356 Brightlingsea
Throw it away or make a tent out of it. Horrible things.
Sounds like you single hand a fair bit.
Get a twizzle or double headsail. I sail a Hunter 356, not fast, I don’t race (except cruiser club racing).
Essentially it’s a double headsail on the same furler. One sheet on each sail. Sailing up wind the “redundant” sail lays against the “active” sail. Turn downwind and make off both sheets. If the wind gets up just roll some away.
If you have a pole then pole out the windward sail and turn to have the wind on the pole side. The double sail will work as one with the wind up to about 20deg aft of abeam.
I am “single handed” most of the time because my wife has MS.
BTW, it’s a “white” sail, so you shouldn’t get penalised when racing.
Likes: Hayden Watson
Sep 27, 2020
24
Tartan, Compac T27, CP19 Stuart
I know this is an old thread but people are still reading it.
First, yes to a twizle rig and other double headed rigs for short handed cruising.
Second, yes also to flying a spin short handed. Racers get used to many hands and everything happens very quickly at the last minute. Carrying a symmetrical spin short handed is an exercise in planning ahead and going slow. One tool is a spinaker net to prevent headstay wraps. I learned spinaker sailing double handed on boats over 60 feet. With a little planning and an eye to windward for squalls it's not bad. Know the order things must be done and don't worry about executing the steps simultaneously.
