I posted this in the "ALL", but not getting much response. I'm getting some rattling noises when in idle or low RPM. The manual indicates worn damper plate. I re-aligned the shaft this spring after raising the motor due to the mounts settling over the years. This miss-alignment has caused some wear on the cutlass bearing, that I will eventually need to deal with (no play at this time). My point being the rattling is not caused by the shaft hitting the boat exit hole as before. I'm guessing it is the damper plate. Has anyone ever changed it on a 310? It would seem from the exploded drawing attached that the bell housing will need to come aft considerably to allow for clearance. When I disconnect the coupling I only have a few inches of clearance max, so then I would need to pull the motor! yuck!!
