Has anyone tried cutting/trimming the blades of KiwiProp to shorten it? I've damaged all 3 ends of the 16" blades and thinking of cutting the damaged portion away. Also shorter blades means I've scope to adjust the pitch. As it is now mine is set to lowest angle (18deg).
So I suppose hack saw and hand files can do the trick? I should try maintain same profile.
