Cutting Board???
Bill P.
I seem to have found what appears to be a large cutting board - plastic with wood trim along one side. Anyone else have one of these and if so, where does itt go???
Dave Slepoy
cutting board
not sure of ypour find but I made teak board to fill in the sink so the galley counter was level and then I added a cutting board to the under side of it. Turn upside down for cutting, flip for more counter space. Be sure to add 2 or 3 stainless washers between the wood and the board so it will dry after cleaning. Dave
L
LaDonna Bubak - Catalina Owners
Cutting boar
Could it fit on top of the stove? LaDonna
Bill P.
Doesn't seem to...
I thought it might acutally slip under the stove cover as it is about that size but it doesn't appeart to fit there. Still a mystery to me. Bill
A
Alan Huffman
Its not a cutting board
It is to slip into the wood pieces which should be on either side of the walk through transom when you don't want to leave it wide open. The wood is handle/trim that goes on the top.
Bill Potter
Thanks!!
Alan: Thanks a ton - never would have thought of that!! Headed to the boat tomorrow and will give it a look see - thanks again! Bill Salt & Pepper
