Cutless bearing replacement questions
Dec 19, 2006
5,832
Hunter 36 Punta Gorda
Rent the tool and not get into removing the shaft which would be a big deal and $$$$$$$$$$$$$ so save yourself a lot
of hard work and who knows what else will go wrong and rent a puller for the prop and should be so much easy with the tool.
Nick
Aug 13, 2012
533
Catalina 270 Ottawa
Au contraire, mon ami. It's not "proper" vs "wrong" spelling.
I don't want to argue, but from what I know, "Cutless bearing" is a trademarked name; whereas the generic name is a "stave bearing" or a "water lubricated shaft bearing". A cutlass is a marine term, as well, but it refers to a short sword with a somewhat curved blade.
Marek
Feb 6, 1998
11,772
Marek
One of the larger stern bearing manufacturers in the world, Vetus, calls their bearings "Cutlass Bearings" ..
