After a bout with the nor'easter we had here in Norfolk in November, I'm forced to make a few extra repairs while the boat is on the hard. Painting the damaged and repaired transom is in order once the temperatures climb again, as is the repair to the bow cleat which pulled free and allowed the damage to occur in the first place (Insert criticism here for not backing it as project #1 when I got the old boat years ago). I've always had a very small weeping from one of the cutlass strut bolts. Pulling the bolts (and keeping the strut in place and not breaking the 5200 seal) revealed a rotted plywood backing. The backing has been replaced and re-glassed. I now need to install the bolts. Choices: 1) Drill the holes oversized, epoxy, drill smaller holes, countersink top (per Maine Sail's advice) and seal holes to bolt with 5200, or 2) Drill holes slightly oversized, install bolts (without the washers/nuts), epoxy bolts in place, then install bolt/washer per WestSystem guidance for through-bolted fasters. As a lurker here for years, any advice is appreciated!
