Going to get the boat out of the water next week, and repair the damage I did to the rudder during my recent grounding incident. The rudder itself is broken loose from the rudder post. From what I have learned, I think I can repair this without having to pull the rudder. Pulling the rudder on this boat (S37) will be a total nightmare, requiring Spider Man and his little brother, as nothing is even remotely accesable. It would be necessary to hire Spider Man, as I know I am no longer limber enough to get into that little hole, let alone do anything once I'm in there. Plus it will take two more pickups with the travel lift, ( one to remove, one to install) or to dig a hell of a big hole in the marina's yard. I would like to replace the cutlass bearing while the boat is out of the water, and am wondering how big of a hassle this is going to be, without being able to pull the shaft. I have changed cutlass bearings in the past, but never without pulling the shaft. Is it possible to split a piece of pipe the proper diameter, rig up a puller and get that puppy out without tearing something up. All ideas and opinions appreciated, and it is OK to tell me I am an idiot for even thinking about doing it this way.
