Cutlass Bearing Change
Dan P
Does anyone have any suggestions or experience to share regarding changing the cutlass bearing on my 2002 Catalina 350 (hull #3)? Since there is no way to get in front of the bearing to push it out, I'm concerned that if I can"t "pull" it out or damage it I would then have to remove the shaft (and thus the rudder) to finish the extraction of the old bearing. Any comments? Dan
Pat
Our organization has .....
... available to them a Strut Pro cutlass bearing removal tool. It (and other tools) is owned by the technical editor and he lends it out to the members of the club. I happen to have the tool now and will be replacing my cutlass bearing this week-end. It allows you to remove and replace the bearing w/o removing the rudder or prop shaft. See www.strutpro.com
I believe that the C350s
have their cutless bearing encased in the hull and not in a strut. Dan, how about trying the C350 website or email list?
Pat
tougher job than I thought
Maybe you'll have to call Catalina...I will be interested to find out how it is done since I have a friend with a 350 too. Please keep us informed.
