Cupro-Nickel HE fittings
Jan 4, 2009
45
Newport N28II Seabrook Ship Yard, TX
Anyone have any experience with Cupro-nickel heat exchangers with respect to fittings? I need to screw on a 3/8" NPT hose barb. Seems like bronze is pretty safe but I can't find anything that small in bronze. Stainless? I assume brass is a no-go?
Jan 4, 2006
7,643
All Depends ............................
................... on whether the fitting is subject to sea water or antifreeze.
You shouldn't have any problems with brass as long it's in the antifreeze side of the loop.
Sea water side ? ? ............ not so good.
Sep 15, 2009
6,244
S2 9.2a Fairhope Al
why not use copper fittings after all there is a lot of copper in the heat exchanger flews...
