CS30 Potty Replacement
276
Catalina 310 Toronto, Ontario
Hi all ....... having a great summer I hope!!!
Anyone here who has a CS30 and has replaced a Head could you possibly give me some feed back about how you went about it. I just removed a Wilcox and found that there is no way to get under the Head to put nuts & washers on your bolts. :confused: Is the underneath structure a metal or wood plate that the bolt screw into.:eek: When removing them they came out with quite a bit of difficulty. Any feed back would be appreciated.
Cheers
Irish Rogue
They are LAG bolts, they do not have any washers or nuts below them. Why? 'Cuz even the factory couldn't get their hands under there either! :)
Here's our head replacement. I suggest a Raritan PHII or PHB or get the LBA pump and use your old bowl, available right here on this website store (sorry, I didn't!). Support Phil and the gang.
http://c34.org/bbs/index.php/topic,3797.0.html
May 2, 2012
276
Hi Stu ...... the bolts are 2 inch stainless steel machine bolts. That is what is throwing for a loop!!! That is what leads me to think that there is metal below.
Cheers
Irish Rogue
