I installed a 2 blade feathering Variprop and can easily reach over 6 kts at 2400 RPM. This is the RPM that the engine seems to run best at, there is a slight resonating vibration at lower RPMs, this was the same with the fixed 2 blade prop as well.
Many here will tell you differently but, as long as you can get the boat insured, having a survey done is ultimately a personal decision. I would heavily recommend a survey to most prospective buyers but in the end it's up to you and your level of risk tolerance.I was not planning on a professional survey, and I know this is a risk, but we have gone over everything on the boat and found some small issues, nothing major so far other than the speed thing.......
Did your 27 have a seawater cooled engine (5411)? Those are designed to run cooler than ones with a heat exchanger, because seawater causes problems at higher temperatures.The purpose of the thread was to mainly find out what cruising speeds are considered normal and at what rpms, and what temp is the engine running at. Our 27 ran at a cool 160 all the time, so 175 seems warm to us but it seems pretty normal.
Depending on what instruments are installed, this may, or may not be an issue. There is a calibration screen on most displays these days that allows offsets to compensate for placement or obstructions to be taken into account.Owner said it never worked right.
same with mine. I do not think mine will even go up to 3,000 rpms. Maybe my tach reads low.On mine we cruise at 5.5 kts @2200 rpm 3 blade prop but I have a 29hp yanmar in my 310
Again a key test is what can you get pushing the throttle all the way forward in neutral. I did mine today and hit 3200 rpm max. Please report back on the sea trialDiver reported running gear was in desperate need of cleaning. Cleaned prop and shaft and added a new zinc. Reported hull was clean with only a few barnacles and they came off easily.
Second sea trial is Saturday. Thanks for all the conversation, I will let you all know how it goes.
