John Baumgartner
I just got back from a trip down St. Johns River in FL. The reason that this is important is that ST. Johns River has a special color to it... BROWN, well in traveling on the river I started to get water comming up from the below deck plates, started the bildge pump and got about 2-3 gal of river water over the side.The port and stb lockers below decks had about 1.5 inch of river water, so the question is:1. is the water comming from a crack in the balast tank?2. is the water comming from the stern deck to hull seal?I've checked the entire exterior hull for any damage and found none.Can I fill the balast tank on the trailer and see if water appears in port or stb lockers?Take the rubber bumper off back aft and see if any screws have worked loose... than repair?Or have I missed something else, The reason I beleave that it is not a topside leak is because of the color of the leakage
