Craziest Rigging Idea Ever?
Nov 8, 2010
11,386
I'm skeptical. Balancing the tone between the sides will only tell you that those two tensions are the same. But the mast could still be bent to one side or another even with equal tensions (at small amounts of deflection the mast likely isn't stiff enough to show a different tension).
3rd time I read this on this thread so jumping in here.
Matching pairs of shrouds are a coupled system. Statically they are ALWAYS in equal tension. Don't believe me? Go try and get them out of equal tension. Only thing you will do is tip your rig! ;^)
Likes: Daveinet
EV21
Apr 29, 2016
94
Macgregor 21 Venture Delaware ...
How about if you hung a known dead weight tension value that you want to achieve from the cable and measured the "note" you get when you pluck the cable. Then, when you re rig you could set tension for your note. Would be interesting to measure the "note value" against a tensiometer to see how close the values track. I think Mark's mention of other items influencing the measurement is no small issue. Would the presence of a spreader act like a fret? Still might make for an interesting activity.
PGIJon
Mar 3, 2012
856
Hunter 34 Punta Gorda
EV....The problem of the know weight is the weight... Based on the specs here (http://www.defender.com/product3.jsp?path=-1|2078767|2079497&id=108067) see below, to achieve a 15% stretch would require a weight of 1,122.15 pounds... That maybe a bit to heavy for me to lug onto the boat.... However, recording the pitch of a perfectly tuned shroud on ones phone might work..... -Jon
1x19 Stainless Steel Rigging Wire 1/4 Inch
  • Type: 316, Size: 1/4" Diameter
  • Minimum Breaking Strength: 7,481 lbs
Sep 20, 2014
1,329
Rob Legg RL24 Chain O'Lakes
About the only thing it could be useful for is to tell you that you are in the ballpark for the correct overall tension. It is only going to be a ballpark number though, as other factors that effect the wavelength of a vibration of a particular object. Ask any guitarist who brings his instrument in from outdoors, and tunes it several times until the instrument equalizes to the temperature in the room.
PGIJon
Mar 3, 2012
856
Just a bit more thinking along thinwater's auditory range... I have 2 sets of spreaders.. that would potentially give me 3 different notes.... Are you thinking what I'm thinking.... Louie Louie...... Just have figure how much to heel the boat to cause each spreader to act as a fret.
Jan 7, 2011
5,659
Oday 322 East Chicago, IN
I think it only tells you that matching shrowds on each side are the SAME tension, but not that they are the RIGHT tension.
If you used a Loos to get the right tension, then determine the "pitch" with you tuner, I guess you could then check it is still "in perfect pitch". But you have to first determine what the right pitch is.
And as others have said, could be lots of interference (wind, etc.) that makes things even less imprecise.
Greg
Mar 26, 2011
3,733
Corsair F-24 MK I Deale, MD
We're all guessing. Someone needs to tension with a gauge, measure the tone, and then match that to a calculation. I'm betting the calculation is more accurate than the gauges, which make assumptions about wire stiffness that aren't always valid.
Jan 25, 2011
2,439
S2 11.0A Anacortes, WA
I'm not guessing. As a musician, i can guarantee a tuner will not resolve the "noise" of a shroud being plucked.....
Jan 25, 2011
2,439
And i agree..just that tuners do not. And plucking a shroud does not produce consonance..(I actually plucked my outer stay today. Had to do it) where's this thread going?
Beneteau 323 Annapolis MD
I'd think you WANT to use the tuner. I mean, when the wind blows and makes the rigging sing, wouldn't you want it in harmony? Tired, I'm going to bed now.
jwing
Jun 5, 2014
503
ODay Mariner Guntersville
My shrouds get out of equal tension every time I sail. Windward tight; leeward loose. But maybe that's not what you consider a static force situation. OK. Even on the trailer, I doubt that my shrouds are equally tensioned; the backstay on my boat is not centered.
Nov 8, 2010
11,386
Correct.
Aug 22, 2011
1,113
As a long time guitar player , I'm thinking that getting your shrouds so tight that they would register on a guitar tuner would result in a rig that is WAYYYY too tight.
Now as far as the keel cable goes - that I can definitely get a note on.
When I hit A 440 I'm smiling. When I hit high C I'm reefing....
jwing
Jun 5, 2014
503
Correct.
OK. If you loaded one side of your boat so that the port gunwale was closer than the starboard gunwale to the water, then even tied in a slip, the starboard shroud would have more tension than the port shroud. This doesn't matter at all; somehow I've allowed myself to get sucked down the hole of intellectual wanking that is this thread.
