couple of Q's
643
SCHOCK santana27' lake pleasant,az
1 what is the watt to amp conversion
2 what is the sgnifigance of a 36' boat?
i know a 27' is the smallest of the big boat class so where does the 36' fit in? is a 37' or 38'change that much in build or ammenities?
I'm noticing a few 36'ers with really good prices on them early '70's models so they'll be pretty solid ?
Alan
Jun 2, 2004
4,174
Hunter 35.5 LI, NY
2 Q's
You cannotconvert watts to amps, since watts are power and amps are coulombs per second (like converting gallons to miles). However, if you have at least least two of the following three: amps, volts and watts then the missing one can be calculated. Since watts are amps multiplied by volts, there is a simple relationship between them.
Boat size is very misleading. It's kind of like the richtor scale for earthquakes. A small increase in length means a huge increase in volume and displacement. Example: a 30' sailboat might displace 7000lbs whereas a 40' might displace 20,000lbs, nearly triple the weight for a mere 30% increase in length.
Sep 19, 2006
643
ya but theres a line where the jump is more pronounced than another or is it just me like 26' is still small boat but 27' is big boat?
... a line where the jump is more pronounced than another ...
Good observation. Here's mine. C22 to C25 doubled the volume with a whole different "feeling" looking from the cockpit forward to the bow. All of a sudden we went from a small boat to a BIG boat in terms of the proportions of the hull, width to length. C25 to C34 didn't feel like a big jump. The hull proportions were pretty much the same and the gear we had on the C25 for sailing were on the C34 or easily added (i.e., vang, cunningham, lines led aft, reefing setup, etc.)
Much has to do with your experience, too.
Then there's the whole issue of bigger boats having more systems to learn to maintain. C22 to C25 - no difference. C25 to C34 - night and day: diesel, electrical systems, plumbing. So, I bought a book! :)
Sep 19, 2006
643
i'm looking at an islander 36' '72 vintage to live on while in san diego maybe get a roommate to share the slip fees with
May 31, 2004
197
Catalina 36 MK II Havre de Grace, MD
Living on a boat, you better get along very well with your roommate.
Oct 14, 2005
2,191
Stu said it...
the jump in size is relative. For me the move from a 27 to my 34 was significant. Tiller to wheel, outboard to inboard, much longer deck, wider and heavier. And many more systems! Casey books, Calder books, Yanmar books, electronics manuals--the "library" fills a Rubbermaid tub!
Sailing, though, is a whole 'nother world! What a difference!
