convert my alcohol stove to flamless
1dandy
Jan 27, 2013
7
Catalina 30 Wiarton ON
I have an alcohol stove that when lighting it, almost burns the boat up.
I have been told there is a similar stove that is flamless, but still works with alcohol.
Any thoughts?
Dan
Sep 15, 2009
6,244
S2 9.2a Fairhope Al
look at Origo and Contour they are both alcohol canister stoves....
regards
woody
woody's right. If the cost of those good stoves is prohibitive for you, consider using a LOT less alcohol in the startup burner. You really don't need a whole lot to get the burner hot.
Mar 20, 2012
3,983
I dont know what stove you have by your post, but if you do a search for origo or cookmate flame diffuser and either get it for your stove, or build something similar, it may help with the problem....
