Engine Alarms
depending on how far you were heeled over, the oil pump may not have been able to suck any oil out of the sump....If you have a Yanmar, there is only one buzzer, but the individual lights should say what they are for. Oil Pressure, Water Temp, and charger.The Oil pressure light should come on when you turn the key, but go out when you start the engine.Find the sensors - if you don't have a shop manual get one from the engine manufacturer. If it is the charging light, indicating a problem with alternator, check the belts. Or replace them... take the alt. to any alternator shop for testing.If water temp search the archives... there have been many discussions on how to correct overheating.
