David, that is my panel. I don't have the manual. What does it say about adjusting the brightness and contrast?
Here’s a copy/paste of that part. I’ll try to upload the full PDF when I’m at my computer later.
3.4. Settings menus
The display unit has a SETTINGS menu allowing the following settings to be adjusted. To access the settings menu, press
and hold for more than 2 sec. any of the 3 function keys, except the WATER key when the metered fresh water level is
displayed.
BATTERY ALARMS
? Turns on/off the 3 audible battery alarms (default: ON at power up). Press briefly the VOLT key to toggle the battery alarm
ON/OFF. In this case, any previously acknowledged alarm is triggered anew and should be acknowledged again.
? After 5 sec. of inactivity, the display returns automatically to the DEFAULT display.
CONTRAST
? Adjusts the display contrast. Press briefly the WATER key to cycle up the value. When the maximum value is reached, the
next press returns the display to the minimum value.
BRIGHTNESS
? Adjusts the display brightness. Press briefly the FUEL key to cycle up the value. When the maximum value is reached, the
