Hi, I recently had to replace the thru-hull connector for the bilge pump in my 1987 O‘Day 272. While the connector was removed I had the opportunity to see both the outer fiberglass hull and the inner cabin liner.
I had expected to find some type of insulation material between the two pieces but I was surprised that the gap between the two walls was empty.
I am a new owner so I don‘t know what I was supposed to find there. Does anyone know where there is supposed to be balsa coring or some equivalent material in the O‘Day 272. Any thoughts are appreciated.
Thanks
Thanks
