Traveler
Marcus,The traveler located in the cockpit has advantages and disadvantages. The major disadvantage is that it takes up cockpit space and is "in the way". However, it allows for easier and better control with less load stress on the boom.It is possible to convert to a coachroof system, not without considerable expense and effort. You will have to research the components to find out what is best for your application. Realize that you will not just be purchasing the traveler, but also the considerable hardware necessary for installing it. You will need a number of blocks, boom fittings, coachroof fittings, turning block at the mast base, backing plates or large fender washers on the underside of the coachroof, etc. Not to mention the necessity of installing a rope clutch. When the job is complete you may find that the loss of control you have traded for more cockpit space is not worth the expense and effort. Before you do anything, sail on a boat with the coachroof system. When I had a 33' boat with end boom sheeting I was able to single hand with ease; something else to consider.PAT
