Well, due to doors not closing and VHF transmission problems, I thought I might have a compression post problem. I took part of the trim off, it was held on with screws, and found what you see in the picture.
Apparently the previous repair has failed due to further degradation in the structure, causing the beam to twist aft. The interior you see is dry. I think that there must be an issue inside the fiberglass beam. I am interested to hear your suggestions on how to approach this issue.
Since it does not appear the fiberglass beam was modified previously, I want to leave it. I propose jacking the beam to release the force causing the thin piece of wood to bow and replacing the wood with a L shaped piece so there is more support and still space for the wires. Then, removing the mast and mast step, try to remediate the problems that I find there.
I remember someone writing about doing a compression post repair from the deck, but I haven't rediscovered it yet. Any help you may provide is appreciated. Thanks.
