Some more wiring hints.....
One of the first things you'll notice when rewiring a boat is that it is EXPENSIVE! After a good bit of searching, I found a place called www.bestboatwire.com that has great prices (1/3 of W.M. price) and good service. Their wire is full marine spec and of very high quality. They also carry the crimp connectors, heat shrink, etc. They're located in Florida and usually drop ship direct from the factory the day after you order. Highly recommended!As to crimp vs. solder, IMHO, soldering is not the way to go. First, to be ABYC compliant, you have to crimp the wire before you solder it, second, the solder makes the conductor rigid right at the connection and that could lead to fatigue breakage. My preferred method is to first coat the bare strands of wire with anti-corrosion gel, then insert into the connector and crimp. Dress that with a piece of adhesive lined heat-shrink and you're good to go. Also, be very careful with those 'automatic' wire strippers, as they often have a tendancy to nick the outer strands of the wire and you really don't want that. A old-fashioned manual stripper is really better, the ones made by Klein Tools are my favorite, as they are professional grade and very well made. As to the crimping tool, a ratcheting 'controlled-cycle' type is your best bet, as it will insure consistency and quality of each crimp. When you get a 'wiresnake' (actually, it's known as a 'fishtape') you should also get something known as a 'worm' to go on the end of it. A 'worm' is a tightly wound spring that helps the fishtape get around sharp corners and it can really make it easier to use. And, trust me, you are going to need a fishtape! Another thing to do, when you first get the fishtape, is to cut-off about the first 2 feet of it to make a seperate, short 'wire grabber'. BTW, this is usually called a 'fishstick'. (us electricians have a lot of weird names for things, kinda like sailors!)Well, thats my two cents worth! Have fun with your wiring project!Jeff
