PVC Pipe Legs
We made some legs out of PVC pipe, 3/4 I think.The inside diameter is just large enough so the bumpers on the cabin top fit inside the pipe. We cut two sets, one about 7 inches just to get the top up, even while sailing and the other longer, so the top is up against the boom - not while sailing.The other end fits nicely at the aft end of the wide part of the channel on the cabin top itself. Measure what you think you need for the height you want. Figure in angles on both top and bottom so they sit flush against the pop top and the channel.Bill BowmanH23 - Joint VentureMuskegon, Michigan
