Coffeemakers
caguy
Sep 22, 2006
4,004
You will do best to use the galley stove.
Speaking of which, where can one buy alcohol for a stove? What kind of alcohol does it use?
Don't want to highjack this thread but I don't want to start a new one over a simple question.
Joe
Jun 1, 2004
8,354
I use to have one in my van for traveling. It took maybe an hour to perk. Unless they have been improved, I suggest you stop at a 7-11 barge for coffee.
Good idea... may I suggest, however, a senior coffee at your local Mac D float through!!! Way better coffee than 7-11. on the ICW near St. Pete.
5
Hunter 38 Solomons
Thanks to all of you who responded. Not sure which set up we'll use, but it certainly won't be one of the 12V coffeemakers. Appreciate your help!
Dec 9, 2008
426
1980 Hunter 30 "Denali" Seaford, VA
French press is great, we haven't had a coffee maker for years (though we have an espresso machine now). We have a few presses, but we prefer (Bodum), I like the insulated stainless steel one for the boat because it's durable, big, and keeps the coffee warmer longer. The grind doesn't need to be that course, you just have to be aware that there may be some sediment on the bottom of the cup and I usually avoid the very last sip.
Jeff
Sep 29, 2008
195
Hunter 33.5 Carlyle Lake in Central Illinois
We bought a 8 cup stainless steel percolator from a local sporting goods store. $20.00 I also put a small filter in it for easy clean up. From start to finish on a non pressurized alcohol stove 15 min. or so.
Jun 6, 2006
6,990
Coffee on board
We use the Coleman camp perculator and a thermos. It does take about 20 minutes to make 12 cups though.
Aug 21, 2006
203
Pearson 367 Alexandria, VA
Having tried several 12 volt units, I echo the stainless steel insulated French Press recommendation. We picked up our press at REI..
Dec 9, 2008
426
While on the coffee topic, but sorta off topic anyone else roast their own? We've been doing it for a couple of years are really enjoy the coffee we roast. We don't have a very good coffee selection for the price around here. I find it to be a rewarding thing to do and great coffee, total control over your coffee, and much cheaper than buying gourmet roasted beans.
Feb 4, 2005
524
Catalina C-30 Mattituck, NY
starbucks makes a decent instant coffee you can use if you just boil some water. I'm not as fan on instant coffee but this happens to be my except to the rule. That is what I would do for coffee onboard.
Dec 2, 1999
15,184
Rob:
That is expensive instant coffe at $0.70/cup.
We get our coffee in individual bags (1 bag = 1 pot) for about $.035/ pot at Costco.
Boil the water and pour it in the Melitta. We use a thermal carfe which keeps the coffe hot for hours. It is really great for an early morning cruise out.
Dec 9, 2006
694
Oday 22 Hickory, NC
Cap Jon, can you start a new thread on how to roast your own coffee? Please!LOL
I went to a roasting company in Jupiter, FL the other day...did not want to leave!
Jack
May 23, 2007
1,306
Catalina Capri 22 Albany, Oregon
The Admiral drinks coffee, I don't. We tried the 12v and even with 2 fully charged batteries (one starting, one deep cycle) we couldn't get it to do anything. We now bring a thermos of hot water, or heat it on the Origo, and she uses the Starbucks instant.
May 9, 2006
56
Beneteau 373 Mystic, CT
Have tried many options but after 30 years, use only my old Farberware stove top percolator. A bit bigger than the current link above. It's quick, efficient and makes great boat coffee. Always use a basket filter.
Dec 9, 2008
426
Jack
You got it... it's a little long winded, so pour a cup or pint depending on what time of day you read it ;). I just wanted to be thorough...
Oct 19, 2009
97
oday 22 Lake New Melones
I use a JetBoil, self contained cooking system, with a french press. I use it for camping, boating, power outages, you name it. My wife drinks tea so we just bought an extra cup to heat water for her. Kinda pricey but considering the use we get out of it, well worth it.
http://shop.jetboil.com/index.php/flash-java-kit-cooking-system.html
Of course I always thought cleanup to be a PITA, so i think I will check out njsail's suggestion.
http://lifehacker.com/5648883/coffee-catcher-filters-and-simplifies-your-french-press-coffee
:eek:What do you mean, I've had enough coffee!!
