Ok then...thx. I knew drummers had shakers underneath their throne when using in ear monitors, but I never heard of these. Just wondering about freq response.
I would guess there is still a reason manufacturers are still using cones.
frequency response depends entirely on the surface you are attaching them to. These are really no different than the voice coils that drive a cone speaker, they are just designed to connect to a flat surface and drive it instead.
You are NOT going to get low sub like bass out of one of these on your boat, you WILL get good mid-range and treble, if you take the time to test and locate a good mounting spot (it took me about 10-15 minutes to test various spots until I was sure of where I was putting them).
The goal is a large flat thin section of fiberglass in the cockpit, that ideally projects in the direction you want to hear. Really use the same logic as if you were going to locate a place for a 6-10" mid-range speaker, where would you put it? Once you know where you would put that speaker, try testing by holding this up against the surface, if the sound is reasonably good, prep the surface, take off the 3M stickers and stick it on, crank up the tunes and you're done!
