Same Project this Summer
Mike, You're right; the water just lays there between the two drains and leaves a mess. I am planing to do the same thing this summer installing flush mount drains in the trough. I have not determind the size of the fitting yet. It will have to be a take it apart and run to West Marine. One thing that you need to look at is the plumbing underneath the deck. I have been all over and under my O'28 and am very pleased with the construction. However, when I spotted a leak coming from that direction under the cockpit floor, I crawled into the locker to take a closer look. What a mess!! It could have been from the PO, but it sure looked like some Friday afternoon quiting time fix from the factory. It will be easy to rectify, but I suggest that you get down in the locker and inspect that part of the installation also. PM
